What is the minimum voltage needed to activate coil on the Kacon 730-1TB-110VAC relay? Would 70 volts be enough?
Kacon 730-1TB-110VAC Relay, SPST, 110V AC, Screw Terminal, Panel Mount
Open Sep 25, 2026 - 04:14 PM
Relays
Sep 28, 2026 - 08:54 AM
The Kacon 730-1TB-110VAC relay has a minimum operating voltage that is 80% of the rated voltage. For this model, the rated voltage is 110VAC, so the minimum would 88VAC. Therefore 70 volts would not be enough to activate the coil. On a related note, the dropout voltage would be 30% of the nominal voltage, or 33VAC.
View all Kacon 730-1TB-110VAC Relay, SPST, 110V AC, Screw Terminal, Panel Mount Questions & Answers
