Sep 01, 2026 - 08:57 AM
There are several different options for bases that work with the Menics MT5C1BL-G tower signal light. This light does require a pole + base (for surface mounting) or a pole + bracket (for wall mounting) for proper installation. Assuming this tower light will be mounted to a flat surface and not to a wall, here are the available options:
MAM-B070C - 70mm plastic base
MAM-B070D - 70mm plastic base with rubber gasket
MAM-B070R - 70mm 180 degree adjustable plastic base
