Aug 12, 2026 - 08:42 AM
With its 40 degree beam angle, the Euri Lighting EP30-11W6020E PAR30 LED light is considered a Wide Spot Light. While the beam angle is not as tight, it is still narrow enough to be classified as a directional spot light. Typically 45 degrees is considered the smallest beam angle for a flood light. However, the EP30-11W6020E PAR30 light is designed for general purpose use, so it is recommended that you confirm if the 40 degree beam is ideal for your application.
