Aug 04, 2026 - 09:50 AM
While the Hirschmann G 4 KW 1 F 4 pole cordset is only available as a single ended connector with 2 or 3 meter cable, there is the Hirschmann G 4 W 1 F, which is just the connector without a cable attached. It may be possible to create a custom assembly with this connector, provided that the spec variations are still suitable to your application. The G4W1F is rated for 6 amps while the G4KW1F is rated for 10. The G4W1F accepts 26-20 AWG conductor sizes while the G4KW1F has an 18 AWG conductor size. The G4W1F also works with 3.5 to 6 mm cable while the G4KW1F has 7.4mm cable. The G4W1F is also slightly wider and taller, with a couple millimeters difference.
After studying the specs for the G4W1F, if you think it will work for you, you can request a quote by emailing us at sales@majorelectronix.com. Our sales team can let you know if that assembly would be possible. If so, since it is a custom assembly, there may be a minimum order quantity, and it would be considered non-cancellable, non-returnable.
