Jul 23, 2026 - 09:39 AM
Crimp pins are not included as standard with the Sealcon M23 7 pole straight female thread connector. Each component, including the housing, pin insert, and contact pins are chosen separately. If a pin insert with solder contacts is selected, then no separate crimp pins are needed. If a pin insert with no contacts is selected, then a set of 7 crimp pins or crimp sockets also needs to be selected.
