Jun 17, 2026 - 09:11 AM
The ILME CDSM-27 insert has spring termination, so it does not use separate crimp pins. The pins are already attached to the insert, which accepts 26-14 AWG wire. The only tool needed to wire this insert is a flathead screwdriver with a 0.5 x 3.5mm blade. Spring termination allows for faster wiring and installation.
