Jun 10, 2026 - 09:06 AM
To crimp the Z+F V30AE000001 end sleeve, first the wire ends would be stripped of insulation. In this case, the recommended strip length is 6mm (0.24"). Then the stripped ends would be inserted into the end sleeve through the insulated side. The uninsulated (metal) part of the end sleeve would then be inserted into the appropriate size crimp tool. The crimp tool will squeeze the end sleeve and wire together so the wire does not come out. It is recommended to crimp twice, right next to each other to ensure a secure hold. It will work with any crimp tool that is compatible with 24 AWG insulated end sleeves.
