Jan 16, 2026 - 08:58 AM
There are several basic things you can check with your N-Tron 110FXE2-ST-15 Ethernet switch to locate and fix common problems. First, make sure the power LED indicator is lit. Then, make sure there is sufficient current reaching the unit. The inrush current is about twice as much as the steady state current. Next, check that the LED indicators for any connected ports are on and check that any connections are secure. Lastly, check that the cable is rated Category 3 or higher. If you've checked all those and it still is not working correctly, you can email us at sales@majorelectronix.com, and we can work with you on troubleshooting the issue.
