Dec 16, 2025 - 09:56 AM
It appears that the Scarlett RF machine uses foot switches similar to the Kacon HRF-M5-Y, but they connect differently, so some modification would be needed. The Kacon HRF-M5-Y foot switch uses lead wires, while it seems the foot switch used with the Scarlett RF uses a 2-pin connector. If a foot switch with a 2-pin connector is what you need, the HRF-M5-Y would not be able to connect to the Scarlett RF directly.
If, for example, you are looking to replace a broken foot switch, you may be able to re-use the existing 2-pin wires. You would need to cut and strip the two wires from the broken switch's connector and connect them to the two lead wires of the HRF-M5-Y. Since the switch function is a simple on/off operation, you can try connecting the wires, and if the machine does not work, you can swap the wires and try again.
