Dec 02, 2025 - 08:42 AM
If the LED power indicator on the Red Lion N-Tron NT24K-TX8 Ethernet module is solid red instead of green, that shows that the power is on, but a fault has been detected. It is recommended to either take out the module and reinstall it into the same slot, or swap it into a different slot on the rackmount switch to see if that clears the fault.
