How does the lighted part of the Kacon B30-27W-24VDC push button switch function, is it lighted when pressed or lighted whenever power is applied?
Kacon B30-27W-24VDC 30 mm Momentary Push Button, White, 24V LED
Open Nov 14, 2025 - 08:29 PM
Tower & Signal Lights, Push Buttons & Switches
Nov 17, 2025 - 09:51 AM
How the Kacon B30-27W-24VDC push button is lighted depends on the wiring. This push button has a 1NO / 1NC contact block. Illumination indicates the switch is closed. If the wires are connected to the Normally Open contact, it lights up only when pressed. If the wires are connected to the Normally Closed contact, the light stays on, and turns off when pressed.
View all Kacon B30-27W-24VDC 30 mm Momentary Push Button, White, 24V LED Questions & Answers
