Oct 13, 2025 - 08:55 AM
The Menics MS70LT-GBFF-B LED beacon light is rated IP50 to indicate partial protection from harmful dust deposits. It is not waterproof or intended for outdoor use. The MS56L series is smaller, with a 56mm diameter, and is wall-mounted rather than surface mounted, but has a rating of IP65. While not completely waterproof, it is completely protected from dust and low pressure water jets from any direction. The MS56L-F10-B is the 110V version and the MS56L-F20-B is the 220V version.
