Jun 11, 2025 - 09:23 AM
DIN 43650 Form A to M12 adapters
We’ve provided several answers to questions related to Omal Din 43650 Form A 2+grd PG 9 - NBR Profile , see some other helpful Q&A related to this product.
Question: What is the mating connector for the Omal DIN 43650 Form A valve connector?
Answer: The mating connector for the Omal DIN 43650 Form A valve connector is the Omal VMA-020-00 DIN 43650 connector, which is linked below. There you will be able to find drawings and specifications on it.
https://www.productsforautomation.com...
Question: What does IP 65 mean on the Omal DIN 43650 Form A connector?
Answer: The IP 65 on the Omal DIN 43650 Form A connector indicates total protection from dust and low pressure water jets from any direction.
Question: What is the PA and Sn material for the OMAL DIN 43650/ISO 4400 Form A valve connector?
Answer: For the OMAL DIN 43650/ISO 4400 Form A valve connector, the PA material stands for polyamide and Sn is tin.
View all Omal Din 43650 Form A 2+grd PG 9 - NBR Profile Questions & Answers
