Mar 05, 2025 - 08:30 AM
Partially, yes, the LP-20 does refer to the size of the Cnlinko LP-20-C05SX-03-401A surface mount connector. The LP in the part number simply refers to the connector series it is part of, while the 20 refers to the installation size, which in this case is 20mm. The full part number also indicates that it is a male, 5 pin socket with a solder wire connection.
