What is the difference between the Mueller BU-11XPN grounding clip and the BU-11APN grounding clip?
Mueller BU-11XPN Unmarked Stainless Steel Heavy Duty Grounding Clip
Open Jan 24, 2025 - 08:34 AM
Test & Measurement
Jan 24, 2025 - 08:36 AM
The difference between the Mueller BU-11XPN grounding clip and the BU-11APN grounding clip is that the BU-11XPN clip is stainless steel, while the BU-11APN is zinc-plated steel. Otherwise, they are the same size, accommodate the same size wire, and are rated for the same current.
View all Mueller BU-11XPN Unmarked Stainless Steel Heavy Duty Grounding Clip Questions & Answers
