Jan 03, 2025 - 09:34 AM
We’ve provided several answers to questions related to Sealcon CD13N9-BK Nylon 1/2'' NPT Dome 2 Hole .10'' (2.5 mm) Insert Cable Gland , see some other helpful Q&A related to this product.
Question: Can you use a different insert on the Sealcon CD13N9-BK cord grip?
Answer: Yes, on the Sealcon CD13N9-BK cord grip, any insert that works with a Sealcon 1/2" NPT cable gland will work which is linked below:
https://www.productsforautomation.com/shop-s/1052.htm?Search=1%2F2%22+NPT+inser
t#/filter:ss_category:Liquid$2520Tight$2520Cable$2520Glands$252FCable$2520Gland
$2520Accessories
Question: Can the Sealcon CD13N9-BK cable gland be used in a fuel tank?
Answer: It is not recommended that the Sealcon CD13N9-BK cable gland be used in a fuel tank, as a fuel tank is normally a Zone 0 hazardous location for which this cable gland would most likely not be suitable.
Question: Is the CD13N9-BK cable gland available in a metal body?
Answer: Yes, there is a version of the Sealcon CD13N9-BK strain relief cable gland with a metal body, which is part number CD13N9-BR. It is made from nickel plated brass.
View all Sealcon CD13N9-BK Nylon 1/2'' NPT Dome 2 Hole .10'' (2.5 mm) Insert Cable Gland Questions & Answers
