Jul 08, 2024 - 10:53 AM
Yes, the Menics MPZ-56G-B buzzer is compatible with the PTE-A-302-RYG-B tower light. However, it does not feature plug and play operation. It needs to be wired in correctly along with the rest of the tower light, as seen in the wiring diagram below:
To make the buzzer sound along with the red light, as highlighted in the above diagram, the gray wire (for the buzzer) and the red wire (for the red light) should connect to the same switch.
If you prefer plug and play operation, it is recommended that an Andon light be used instead. There are versions of Andon lights that come with the buzzer already attached and wired to sound with the flashing red light. Here are some options for Andon lights below:
ATEP-RYG-B
ATEP-RYG-Z
ATEPR-10-RYG-B
ATEPR-10-RYG-Z
ATEP-RYG-B
ATEP-RYG-Z
ATEPR-10-RYG-B
ATEPR-10-RYG-Z
