May 28, 2024 - 12:11 PM
When using the Light Efficient Design LED-EMG-10WCP emergency driver, the old CFL ballast needs to be removed. Installation instructions are printed on the actual carton of the driver, and the wiring diagram is on the product itself (see image below). You can also view the wiring diagram for the 5W version of the driver here (which is the same for the 10W version). LED-7230 is not a valid part, however LED-7320 is. They will work with the LED-7320-G3 and G4 series, as well as the LED-7324 series.
Installation instructions for the LED-7320 series is linked below if you need it:
