Mar 06, 2024 - 12:38 PM
The Boxco BC-AGS-2201 push button enclosure has a 22 mm diameter switch hole. It won't fit with the diameter 16 mm of K16-271-G. There is not currently a plastic push button box that has a 16mm hole. There is an aluminum switch box (MB57-S01) that has a 16mm hole, which currently has a lead time of 2-3 weeks. Otherwise, the manufacturer may be able to drill custom holes into the BC-AGS-081107 plastic enclosure, which is the same size as the BC-AGS-2201. There would be a lead time and minimum order quantity for a custom order. If you would like a quote or have questions on either of these options, you can email us at sales@majorelectronix.com
