what 110 ac to 24 vdc power supply do you recommend using? how many amps?
Qronz TL70BK-NRYG-LN24 3 Stack LED Tower Light, 24V
wanting to connect light to an inside 110 ac outlet and use a power supply to change to 24vdc. just want make sure get a power supply with correct amps
Open Feb 05, 2024 - 08:14 AM
Tower & Signal Lights
Answers
Feb 05, 2024 - 08:20 AM
As long as the power supply will ensure a 24V DC output, the amps will not matter. Each lamp on the Qronz TL70BK-NRYG-LN24 tower light is less than 5W, so a 20W LED driver is enough for a 3 tier tower light. As long as the transformer can provide 24V DC the amps won't make a difference.
View all Qronz TL70BK-NRYG-LN24 3 Stack LED Tower Light, 24V Questions & Answers
