Jul 06, 2023 - 03:30 PM
There are two possible 24V lighted DIN 43650 connectors that may work. Both have LEDs that light up either red or green depending on the pin. If these don't work, you can email us at sales@majorelectronix.com with specs of your end device, and we can pass that info along to the manufacturer to see if they have something that will work. If you are interested in purchasing either of these, you can also email us at the same address for a quote. The data sheets for both are linked below:
The GDM31F6-P1J-10D lights up between pins 2 and 3 for 3+ground variants:
GDM31F6-P1J-10D data sheet
The GDM31F6-P2J-10D lights up between pins 1 and 3 for 3+ground variants:
GDM31F6-P2J-10D data sheet
