May 31, 2023 - 02:38 PM
The Menics H10F-12G LED indicator will not work with 2.38VAC, as it is a DC voltage model. The H10F-10 will also not work, as the voltage is too low. Options you can try would be to use the H10F-10G with a 120VAC power supply or to use an AC to DC power transformer (120VAC to 24VDC or 12VDC) to connect H10F-24G or H10F-12G. If you need a lot of LED indicators, we can reach out to the manufacturer to see if a custom part can be made, however there would be a minimum order quantity of 500 pieces and it would be considered non-cancellable, non-returnable.
