With the Lumberg Automation RKU 12-256/10M M23 molded cable Fit Baumer BHF or EIL580P encoder?
Lumberg Automation M23 Cordset, Female, PUR Cable, 12 Pin, 10 M
I need a M23 12Pin CW that will fit our BHF or EIL580P encoders. If you need more info please request.
Open May 19, 2023 - 12:07 PM
M23 cables & connectors
May 19, 2023 - 02:02 PM
Yes, the Lumberg Automation RKU 12-256/10M M23 molded cable will fit with the Baumer encoder, however, it has different color code assignments than what Baumer calls for in the manual. So this M23 molded cable can be used but you will have to use Lumberg's wiring assignment to make sure it’s properly terminated.
View all Lumberg Automation M23 Cordset, Female, PUR Cable, 12 Pin, 10 M Questions & Answers
