Apr 06, 2023 - 03:16 PM
The three modes of operation on the Light Efficient Design SL-SWL-20W-40K-BK-G2 LED mini wall pack solar light are PIR motion sensor mode, timer mode, and full brightness. There is a red button located on the bottom right of the light. Press this button to toggle between the three modes. To get to full brightness mode, the button would need to be pressed three times. In full brightness mode, the light remains at 100% brightness until dawn. PIR motion sensor mode dims to 10% brightness with the motion sensor active. Once the motion sensor is active, it will shine at 100% brightness for 30 seconds. In timer mode the first 3 hours of use will be at 25% brightness and then switch to Mode 1 (Motion sensor).
