Mar 07, 2023 - 02:30 PM
The Hirschmann 933111-100 GSSNA 300 Din 43650 Form C Male appliance connector is typically mounted to a solenoid valve with fixed screw slots. If you were to panel mount this connector, you would need a hole in the panel to allow the soldered wires to pass through. The hole would need to be less than 8 mm in diameter so that it leaves room for the screw positions, as shown in the dimensional diagram below:
