Feb 14, 2023 - 10:20 AM
The Macromatic LCP2H250 liquid level relay should work. When the probes are different lengths, and the fluid in the tank reaches the high probe and senses a lower resistance between the high and low probe, it switches the relay off. When the fluid sees a high resistance between the low probe and the reference, it turns the relay on. If the reference and the low probe are the same length, it shouldn't matter. The fluid will be below both, a high resistance will happen, and turn on the relay.
