Sep 28, 2022 - 09:54 AM
Yes, the Fandis FF15A230NF fan filter assembly can have reverse flow. If you want the air drawn inward into the cabinet (standard flow), nothing needs to be done. If you want air drawn from inside the cabinet to the outside (reverse flow), you need to unscrew the fan and flip it over. For a size 15 you will probably have to check the cabling to make sure it is connected properly.
