Aug 24, 2022 - 03:37 PM
A similar panel meter to the Red Lion C48CS003 panel meter would be the Red Lion PM500D0301600F00 graphical panel meter, along with the PMM000I0RL200000 dual relay output module and PMM000PWACP00000 AC power module. You will need to verify the power source requirement, as the panel meter is DC powered and requires the power module to in order to run on DC power. You will also need to verify the type of output and the number of outputs you need. The PM500D0301600F00 panel meter performs a similar function to the C48CS003, however the programming is quite different. Linked below is the installation guide for the PM500D0301600F00 panel meter for more information:
Red Lion PM500D0301600F00 panel meter
