The ILME CHV-24 Size 104.27 C-Type hood will work with any size 104.27 insert. Male inserts have an M in the product code and female inserts have an F in the product code. The numbers at the end list how many pins the insert has (Example- CDF-64 indicates a female 64 pin insert). You will need corresponding male and female inserts (Example - both CSHF-24 and CSHM-24). Compatible inserts include:
CDF-64, CDM-64
CDDF-108, CDDM-108
CQEF-46, CQEM-46
CSHF-24, CSHM-24
CDSHM-42, CDSHF-42
CCEF-24, CCEM-24
CNEF-24T, CNEF-24TX, CNEM-24T, CNEM-24TX
CSEF-24, CSEM-24
CSSF-24, CSSM-24
There is also a link below to the size 104.27 inserts:
104.27 ILME insertsYou will also need a surface mount or bulkhead mount base for a complete installation. Those are linked at the bottom of the product page below the description. The CHV-24 will work with any C-Type, size 104.27, double lever base. This includes CHP-24.2, CHP-24, CAP-24.29, CHI-24, CAP-24.229, and CAP-24.21
