Jul 19, 2022 - 12:18 PM
If you are looking to purchase the Euri Lighting EUHB-MMS motion sensor, it is intended to work specifically with the first generation of Euri Lighting UFO style high bay lights and will most likely not be compatible with high bay lights from other manufacturers.
When you look for a motion sensor, you'll want one that can work with lights from different manufacturers. Other things you'll want to check are the specs for the motion sensor, you'll want to make sure it is compatible with the lights you have. This especially pertains to wattage. The sensor has to be compatible with the wattage from the light. In this case 250 watts. You'll want to make sure the motion sensor will still work properly with the height of the light fixture (the EUHB-MMS has a height limit of 15 feet) and will provide the sensing distance you need. Another thing to take into consideration is the mounting/installation method. Some sensors are remote, while others are attached to the light fixture housing. For example, the EUHB-MMS is designed to be screwed into a Euri EUHB high bay light.
