Jun 21, 2022 - 09:04 AM
The area should be dry and clean of debris before EternaBond can be applied. Remove the lining as the tape is being applied to prevent mistakes and keep the tape from coming into contact with other surfaces or objects. Pressure should be applied to set up the bonding process and remove any air bubbles. This can be done with your hand, although a steel roller provides the best results.
