Jun 03, 2022 - 08:28 AM
To test an 8 pin relay, use the probe leads of a multimeter on the terminals of the relay to measure the resistance. The resistance should be within the acceptable range for that relay. It's important to know what pins to test, so check the data sheets or the relay itself to see the pin configuration.
