May 27, 2022 - 09:07 AM
Grounding clips lower resistance and static electricity around equipment. A grounding cable is attached to the clip and the clip is then attached to a metal surface. There needs to be metal-on-metal contact, so if the surface is painted or coated, the clip needs to be able to pierce through the paint or coating.
