WHAT IS THE BENEFIT OF USING NICKEL PLATED BRASS MATERIAL INSTEAD OF A NORMAL IRON ALLOY TYPE EX CERTIFIED REDUCER?
Sealcon PG 11 to PG 9 Reducer - RP-1109-BR
MY ENCLOSURE IS EX D AND THE CABLE ENTRY GLAND IS NICKEL PLATED BRASS, IS IT SUITABLE TO USE OTHER THAN A NICKEL PLATED BRASS REDUCER BETWEEN GLAND AND ENCLOSURE?
Open Jan 21, 2022 - 11:17 PM
Thread Adapters
Jan 24, 2022 - 11:44 AM
It is recommended that if you are using a metal cable gland, that the reducer be of the same type of material. Therefore, if you are using a nickel plated brass cable gland, the reducer should also be nickel plated brass. Using mixed metals can cause an oxidation reaction.
View all Sealcon PG 11 to PG 9 Reducer - RP-1109-BR Questions & Answers
