Nov 29, 2021 - 11:42 AM
There could be a few causes as to why your LED canopy lights started flashing. It could be because of voltage fluctuations, loose or faulty wiring, a poor connection with the light switch, or loose connections within the fixture. If you have them on a dimmer switch, that can also cause issues, these are not made to be dimmable. Other electrical equipment that shares the same voltage could be causing an overload to the circuit. On a similar note, if your facility shares a transformer with neighboring facilities, their electrical use could have an impact on yours.
If it turns out you need to replace them, these are discontinued, as the manufacturer is no longer in business. However, we do have a few other LED canopy lights to choose from.
