Sep 15, 2021 - 08:14 AM
We’ve provided several answers to questions related to Menics AVG-10-Y 135mm Beacon Light, 110V, Yellow, Rotating , see some other helpful Q&A related to this product.
Question: Does the Menics AVG-10-Y signal beacon light come in clear?
Answer: For the Menics AVG-10-Y signal beacon light, clear is not a standard option, however AVG-C is a clear lens that can be used with the AVG series beacon lights which is linked below:
https://www.productsforautomation.com...
Question: How much light does this beacon light put out?
Answer: The Menics AVG-10-Y beacon light has a light output of 28 Lumens or 2230 mcd.
Question: Is the Menics AVG-10-Y signal beacon light available with an LED?
Answer: No, the Menics AVG-10-Y signal beacon light is not available with an LED in this series. The closest equivalent would be MS135T-RFF-Y. It is rated for 100-240V and has a flashing and rotating LED.
View all Menics AVG-10-Y 135mm Beacon Light, 110V, Yellow, Rotating Questions & Answers
