Sep 13, 2021 - 08:49 AM
To get the correct length on the Red Lion C48CS003 panel meter, you'll need an encoder with an open collector output signal wired to it. Then scale the counter based on the pulse rate for the length you want the display to read in, such as feet, for example. For your convenience, the instruction manual is linked below:
Red Lion C48CS003 panel meter instruction manual
