What is the brilliance of the Menics LED indicator H08F-20G? Is it viewable in sunlight? What is the candela rating?
Menics H08F-20B LED Indicator, 8mm, Flat Head, 220VAC, Blue
What is the brilliance/brightness other than hi intensity, what is the number rating in brilliance?
Open Sep 10, 2021 - 03:53 PM
Tower & Signal Lights
Sep 10, 2021 - 04:20 PM
The luminous intensity, or brilliance of the Menics H08F-20G LED indicator is 200-300 mcd, which is measured in millicandela. That would convert to 0.2-0.3 candela. While it is possible to see the high brightness LED indicators in sunlight, they are mainly intended for use indoors, as they provide better performance inside.
View all Menics H08F-20B LED Indicator, 8mm, Flat Head, 220VAC, Blue Questions & Answers
