Apr 01, 2021 - 09:57 AM
The difference between a stainless steel and the nickel plated brass cable gland is that the stainless steel does not conduct heat as much and is typically stronger than nickel plated brass.
It is good for food and beverage applications as it prevents fungus growth. Nickel plated brass is not as expensive. It is useful in telecommunications as nickel plated brass has EMI/RFI compatible versions.
