Mar 10, 2021 - 08:58 AM
As liquid enters the POD-TD level sensing drain, it lifts the operator, which has a magnet on one end to draw up the valve shaft. This releases the pressure above the valve shaft and allows the liquid to drain out.
We’ve provided several answers to questions related to Jorc 3805 POD-TD Level Sensing Drain, Triple 1/2'' NPT, 44-230 PSI , see some other helpful Q&A related to this product.
Question: What is the inlet thread size for the Jorc 3805 POD-TD level sensing drain?
Answer: The inlet thread size for the Jorc 3805 POD-TD level sensing drain is 1/2" NPT.
View all Jorc 3805 POD-TD Level Sensing Drain, Triple 1/2'' NPT, 44-230 PSI Questions & Answers
