Feb 10, 2021 - 09:26 AM
The ILME CGFA-35 is actually a female crimp contact pin rather than an insert. It has a temperature rating of -40 C to 125 C (-40 F to 257 F). These contact pins are only used with the 104.27 size, 6 pole CX series inserts, or MIXO series inserts.
If you are looking for a standard insert, since the CHI-16L is size 77.27, it would need an insert of corresponding size. The standard inserts are listed below. They all have temperature ratings of -40 C to 125 C (-40 F to 257 F).
CDF-40, CDM-40
CTM-40R, CTSF-40L, CTSM-40L, CTSF-40R, CTSM-40R
CDDF-72, CDDM-72
CQEF-32, CQEM-32
CSHF-16, CSHM-16
CCEF-16, CCEM-16
CNEF-16T, CNEM-16T, CNEF-16TX, CNEM-16TX, CSEM-16, CSEF-16,
CSSF-16, CSSM-16
CTSEF-16L, CTSEM-16L, CTSEF-16R, CTSEM-16R, CTF-16L, CTF-16R, CTM-16L, CTM-16R
CPF-06, CPM-06
CXF-6/36, CXM-6/36
CXF-12/2, CXM-12/2
CXF-4/0, CXM-4/0, CXF-4/2, CXM-4/2
If you are using the CGFA-35 contact pin with a MIXO series insert, the inserts it would go with are listed below. Both are rated for -40 C to 125 C (-40 F to 257 F).
CX-01GF
CX-02GF
If you are using MIXO series inserts, you would also need the 4 module frame made for 77.27 size housings: CX-04TF
