Feb 01, 2021 - 10:27 AM
Below is an image of the PG 7 cable entry side of the HTP 12FB4000 M12 4 pin female right angle connector. The PG 7 cable entry can accept connector cables with an outer diameter of 4 mm to 6 mm (0.16" to 0.24").
This connector would fit with a corresponding 4 pin male M12 connector. There are several options depending on what you need, including straight or right angle field wireable connectors, or panel mount connectors with front or back mounting, with solder contacts, PCB contacts, or soldered wires.
