Dec 14, 2020 - 10:19 AM
As long as the cable fits the size and shape of the slot opening for the CD16NS-03 Romex cable gland, it should be compatible for this fitting. The slot size for this fitting is 0.2" x 0.45" (5 x 11.5 mm). There shouldn't be more than 1 mm (0.04") of difference between the size of the cable and the size of the slot to provide an ideal fit. The cable can also not be any larger than the slot size. We can also send you a sample piece so you can see if it will provide the water tightness you need.
