Oct 08, 2020 - 04:36 PM
We’ve provided several answers to questions related to Remphos RP-UVC-LC1-38W 38W UV-C UltraViolet Germicidal Light , see some other helpful Q&A related to this product.
Question: Can the Remphos RP-UVC-LC1-38W 38W UV-C UltraViolet Germicidal Light be used in a bedroom?
Answer: Yes, the Remphos RP-UVC-LC1-38W 38W UV-C UltraViolet Germicidal Light can be used in a bedroom. Keep in mind that it cannot be used while the room is occupied and the UV light may cause fabrics to fade over time.
Question: can I see pic of the remote control for the Remphos RP-UVC-LC1-38W UVC Germicidal Light?
Answer: Yes, below is a picture of the remote control used with the Remphos RP-UVC-LC1-38W UVC Germicidal Light:
Question: Is the Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light safe to use around artwork and photographs?
Answer: The Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light uses UV-C light which can damage or fade certain materials. Expensive artwork should be removed while light is on.
Question: Can the Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light be serviced?
Answer: Aside from replacing the bulb, there are no serviceable parts. It is not recommended to take apart or modify the Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light.
Question: Is the Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light safe to use around fabrics?
Answer: The Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light is not recommended for use around expensive artwork or fabrics. The UV light can fade certain materials.
Question: Is the lamp for Remphos RP-UVC-LC1-38W ultraviolet light replaceable?
Answer:
Question: Can the Remphos by Light Efficient Design LumiCleanse RP-UVC-LC1-38W ultraviolet light be used around plants?
Answer: No, the Remphos by Light Efficient Design LumiCleanse RP-UVC-LCI-38W ultraviolet light cannot be used around plants because it can damage them.
View all Remphos RP-UVC-LC1-38W 38W UV-C UltraViolet Germicidal Light Questions & Answers
