Oct 02, 2020 - 10:05 AM
If the 1/4" NPT fitting is too large, we have two other possible options for this vacuum pressure gauge. The PB158B-V30 has a 1/8" NPT center back mount fitting, however it goes up to 30 PSI rather than 60 PSI, and has a 1-1/2" dial size rather than a 2-1/2" dial size. If you can use a lower mount fitting, there is also the PB158L-V60, which does go up to 60 PSI, and has a 1-1/2" dial size with a 1/8" NPT fitting.
