Sep 18, 2020 - 03:48 PM
The Cnlinko LP-20-J02SX-01-001 2 pin connector works with 12-14 AWG wire and is rated at 500V. There is a new series called the LP-28 series, that can work with wire gauges up to 6 AWG, however these are also rated at 500V and are larger than the LP-20 series (see images & drawings below). They are also only compatible with each other, so the LP-28-C02PE-21-001 plug and LP-28-J02SX-23-401 socket would have to be used together.
