Sep 11, 2020 - 03:54 PM
The DuraChoice T3D25500 bi-metal thermometer only measures temperature, so it does not have a pressure rating. If you are looking for a pressure gauge, we have a large selection of both oil filled pressure gauges and dry utility pressure gauges. The oil filled pressure gauges can measure from 0-15 PSI up to 0-15000 PSI, while the dry utility pressure gauges can measure from 0-15 PSI to 0-6000 PSI, depending on the model. We also carry vacuum pressure gauges that can measure down to -30 HG.
